Author Topic: YYYY Date format in RTF output  (Read 6440 times)
AndyBo
« on: September 15, 2010, 07:13:18 pm »
The RTF editor allows the entry of Date Time. AFAICS the formats are fixed.
Does anybody know how/if I can insert the date in YYYY format?
The rationale for this is, I want to add it to the document footer as part of the copyright.
Thanks in advance
« Last Edit: September 15, 2010, 07:13:55 pm by AndyBo »
RoyC
  • Read The Help!
Re: YYYY Date format in RTF output
« Reply #1 on: September 16, 2010, 08:52:03 am »
There are two topics in the Help that might be of value. The first is the Add Content topic, which contains the note:
If you select a field with short date format (such as Pkg.DateCreatedShort, Diagram.DateModifiedShort or Element.DateCreatedShort) the format is actually drawn from the MS Windows settings. To use a different short date format, click on the Start icon on the Windows desktop and select the Control Panel | Regional and Language Options | Customize option.
The second topic is Styles, Special Text, Table of Contents, where we describe how to insert date and time fields:
Move the cursor to the point at which to insert the current date and time, and select the Insert | Date and Time menu option. The Insert Current Date/Time dialog displays, from which you select the required date and time format.
Best Regards, Roy
