Author Topic: Automating the HTML Report (Schedule/On Demand)  (Read 8009 times)
agdunn
« on: November 01, 2008, 06:01:08 am »
We are running a decently sized project now (10 contributors, 500+ diagrams) we have a web server which hosts the output of the html report from EA. I have installed EA onto said web server and use vnc to kick of generations when needed.
I would really like to write an app that would enable my team to kick a report generation off without needing access to the server (through a web interface) or likewise set it up to do a generation based on a schedule.
I saw a while back that a gentlemen was working on this in the forums, i dont know if any of you remember. If not then could you point me to the right place to start investigating the EA api's.
Thanks everyone!
Oliver F.
    • Karl Storz homepage
Re: Automating the HTML Report (Schedule/On Demand
« Reply #1 on: November 03, 2008, 11:20:58 pm »
Not sure whether you are refering to me but I did it.
I wrote a daemon in JAVA which sits in the system tray and waits for a scheduled time, then (besides some other tasks) creates a HTML report. In fact it can even be run as a Windows service.
Basically you will have to connect to the repository, identify the root package as a starting point for the export and then trigger the HTML reporting method.
Connect to the repository:
eaRepository = new org.sparx.Repository();
        if (eaRepository == null)
                errorMessagePopup("No repository available");
                return false;
        if (!eaRepository.OpenFile(CONNECTION))
            errorMessagePopup("EA repository not accessable");
            return false;
        eaRepository.ChangeLoginUser("admin", "...");
We have to change the current login user to be able to have the appropriate rights.
Get the first root package:
         Collection<Package> c = eaRepository.GetModels();
            for (short i=0;i<cp.GetCount();i++)
                pck = cp.GetAt(i);
                pck.ApplyUserLock();
                                        eaProjectInterface.RunHTMLReport(pck.GetPackageGUID(), EXPORTPATH, "png", "<default>", ".html");
This is basically it. I omitted try/catch blocks here for readibility but make sure you catch possible exceptions as often as possible.
I hope this  helps.
Oliver
« Last Edit: November 03, 2008, 11:23:11 pm by ofels »
agdunn
« Reply #2 on: November 07, 2008, 06:46:36 am »
Thanks so much oliver, Would you mind briefly explaining how you set this up to run as a system tray app or a service?
Oliver F.
« Reply #3 on: November 07, 2008, 07:09:52 pm »
This goes beyond EA so it is going to be offtopic.
I can only speak for JAVA apps at the moment, as I did not do it for other languages.
Basically you can search sourceforge.net for a software which encapsulates the windows service API and lets it run as a Windows service.
Search for the terms "JAVA" and "Windows service".
To run it in the system tray SUN has introduced the abstract System.SystemTray class to get access to the instance and the java.awt.TrayIcon API.
If you look in a recent JAVA API documentation you can easily find how to accomplish this. I believe some GUI tutorials from SUN also cover this issue.
Hope this helps.
Oliver
Anne
« Reply #4 on: November 25, 2008, 10:02:26 am »
This looks promisinga nd I'm going to try to implement it this weekend.  But where do I find the java packages to use on this (i.e. org.sparx.Repository)?
Oliver F.
« Reply #5 on: November 25, 2008, 09:05:21 pm »
From the SparxSystems directory go to EA/Java API
There is a ReadMe which will help you further.
Oliver
agdunn
« Reply #6 on: November 26, 2008, 01:12:58 am »
Anne let me know if you get anything working, I had started writing this project but had to sideline it  :(
I am hoping to get back to it soon, but dont know when.
Anne
« Reply #7 on: November 27, 2008, 03:25:20 am »
Oliver
Can you give me an exact URL - I'm not having any luck finding the API.
Alain Bo
« Reply #8 on: November 27, 2008, 04:14:17 am »
C:\Program Files\Sparx Systems\EA\Java API\readme.txt
Anne
« Reply #9 on: November 27, 2008, 04:20:41 am »
 ;) thanks.  I was thinking it was a download.
