Author Topic: 'mailto' Hyperlinks on Diagrams  (Read 12431 times)
Dorian Workman
« on: September 05, 2009, 07:23:09 am »
In 7.1 I was able to place 'mailto' hyperlinks on diagrams, but these seem to no longer work in 7.5, presumably because of the updates to the Hyperlink dialog.
Anyone know how to make these work in 7.5 please?
Thanks.
« Last Edit: September 05, 2009, 07:23:34 am by dworkman »
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
Re: 'mailto' Hyperlinks on Diagrams
« Reply #1 on: September 07, 2009, 09:00:14 am »
Try setting Hyperlink Type to "Web Site" and Hyperlink Address to "mailto:[email protected]".
« Reply #2 on: September 08, 2009, 12:08:28 pm »
Hi Neil,
That works, but it leaves an interstitial "Navigation was Cancelled" message and web diagram.  This will confuse and upset the "punters".
Is there any way to suppress that spurious functionality?
Is a feature request needed?  I'm going to need this functionality to work "seamlessly" very soon.
[EDIT:  The mailto: hyperlink doesn't work at all on the Web output - which is where I REALLY need it!  :( - reported]
« Last Edit: September 08, 2009, 12:19:15 pm by PaoloFCantoni »
Dorian Workman
« Reply #3 on: September 08, 2009, 03:45:17 pm »
Yes sorry my original post was not clear. These used to work in the HTML output in 7.1 and stopped working in 7.5. You submiited a bug report Paolo?
« Reply #4 on: September 08, 2009, 04:17:20 pm »
Sure did!
Dorian Workman
« Reply #5 on: September 09, 2009, 03:40:49 am »
Sure did!
Thanks!
Dorian Workman
« Reply #6 on: September 11, 2009, 02:18:01 am »
Did Sparx acknowledge the issue Paolo?
« Reply #7 on: September 11, 2009, 11:30:59 am »
Yes Dorian,
they have logged two issues:
  • One that the Diagram doesn't respond (in HTML mode)
  • That the mailto causes the interstitial error message (I think, perhaps Sparxian Dermot can confirm my interpretation of this second one)
« Last Edit: September 11, 2009, 02:03:36 pm by PaoloFCantoni »
RoyC
  • Read The Help!
« Reply #8 on: September 11, 2009, 12:58:42 pm »
(I think, perhaps Sparxian Dorian can confirm my interpretation of this second one)
(Sorry, PAOLO wrote....)
?? Ain't no such crittur 'round these parts!  Gosh darn it, them Dorians is mystical thangs.
« Last Edit: September 11, 2009, 01:01:41 pm by RoyC »
Best Regards, Roy
« Reply #9 on: September 11, 2009, 02:07:21 pm »
OOPS!  My bad...  :-[
A case of RTFE (E for email)...  Should have said Dermot...  Refactored...  [smiley=thumbsup.gif]
Dorian Workman
« Reply #10 on: September 11, 2009, 04:07:26 pm »
I have never been called mystical before.... I like it!  ;D
« Reply #11 on: October 18, 2010, 10:25:35 pm »
[size=18]...[/size]
Still doesn't work over a year later...  And I need it even more NOW...  :o
BTW, the interstitial navigation canceled is also still there.
philchudley
« Reply #12 on: October 18, 2010, 10:52:51 pm »
I believe I have seen a customized HTML template with a Javascript mode for this, adding a mail to link on diagrams for HTMNL documentation
It is available for download on the Sparx Community Site (not this forum)
I have tried it and it works, certainly for version 8.0, I assume also for version 7.5
Cheers
Phil
Models are great!
« Reply #13 on: October 19, 2010, 10:14:33 am »
I believe I have seen a customized HTML template with a Javascript mode for this, adding a mail to link on diagrams for HTML documentation
[size=18]...[/size]
Thanks for the pointer Phil (see: Add Diagram Feedback and Comment Link to HTML Report).
However, this solution has a number of problems for my needs.  It applies ONLY to HTML and applies to ALL diagrams.
I'm specifically after the fix to the Hyperlink - so that I can have the same functionality (which used to be there) in both HTML and direct model.
Having had a look at the generated HTML, it's a bug pure and simple - EA emits incorrect HTML.  The best solution, I suspect, is to add a new type of hyperlink (Email) which is specifically set up to correctly emit the required mailto: expression.
