Author Topic: Problems with java code generation  (Read 2620 times)
pstein
« on: November 03, 2010, 11:50:36 pm »
When I want to generate java code from data class diagram then some but not all the variable have a prefix "m_"
How can I tell EA to omit the generation of these "m_" s?
Yes, in tools->options->source code enegineering I listed already in the appropriate entry field "Remove prefixes....":
....;m_;
but it didn't help.
How can I achieve it otherwise.
Furthermore I wonder how to generate also getXXX() and setXXX() for all variables. In  tools->options->source code enegineering->Java
there are already get and set prefixes defined.
Why does that not work? Do I have to check "Disable Language" additionally?
Peter
Re: Problems with java code generation
« Reply #1 on: November 04, 2010, 08:50:28 am »
The remove prefixes option and property prefixes apply when creating properties from attributes.  This doesn't happen automatically when performing a generation, but you can run a transformation to make it happen.
Other than that, it is a matter of manually clicking the 'Property' checkbox on the attributes dialog.
