Author Topic: How to import models as a copy and not as a refere  (Read 3085 times)
pstein
« on: February 03, 2011, 11:10:22 pm »
How to import models as a copy and not as a reference into *.eap container?
A while ago I setup an *.eap container and imported some external models (= *.xml files).
After the import the size of the *.eap file is still very small (approx 2 kb).
So I guess I imported only references to the external *.xml files rather than the model themselves.
Assume such an external referenced *.xml is changed/replaced by a newer version
(e.g. by copying in WinExplorer). Are then automatically the visible diagrams inside the *.eap container
(after a restart) automatically updated? Or do I have to perform an explicit "refresh"?
How exactly can I tell EAP (during import procedure ?) to import a FULL COPY of the external *.xml
files instead only of a reference?
Can I tell EAP AFTER an IMPORT-REFERENCE-ONLY operation to import/copy the full *.xml files anyway?
Or is the relationsship *.eap container vs. model fixed for the lifetime?
Peter
Re: How to import models as a copy and not as a re
« Reply #1 on: February 04, 2011, 12:26:35 am »
Peter,
If EA imports xml files it imports them completely. So all model information is stored in the eap file.
