Author Topic: Problem: Import DB schema from ODBC source  (Read 5826 times)
metasemantics
« on: April 01, 2011, 03:04:05 am »
I setup and ODBC connection to an Oracle database. When I go to my package structure within Logical view as specified on http://www.sparxsystems.com/enterprise_architect_user_guide/software_development/importdatabaseschemafromod.html, and select "Import DB schema from ODBC source", I get an "Unable to Obtain Table Information" error.
Can someone please suggest the best way to get this working?
thanks!
Re: Problem: Import DB schema from ODBC source
« Reply #1 on: April 01, 2011, 07:04:30 am »
No idea, but it could be a rights problem. Try as DBA
metasemantics
« Reply #2 on: April 02, 2011, 12:25:08 am »
I am able to connect to the oracle database and run queries using the same login credentials. I tried using sys dba privileges - same problem.
metasemantics
« Reply #3 on: April 02, 2011, 01:20:03 am »
Has Anyone used Code reengineering to import oracle schema by connecting to the database using EA? Which version and How?
« Reply #4 on: April 05, 2011, 01:40:01 pm »
EA is particularly picky when it comes to drivers for Oracle.
If you search the forum for 'odbc' and 'oracle' I'm sure you should have a lot of results that can help you further.
PS. Use the top left search button, and make sure you look for "all posts", and not only "last week".
philchudley
« Reply #5 on: April 05, 2011, 05:18:43 pm »
Are you using the Windows Oracle ODBC driver? As Geert suggested, EA won't work with this driver  :(
Try using the ODBC driver supplied by Oracle, then it should work OK for you.
Let's us know how you get on
Cheers
Phil
Models are great!
