Author Topic: Relationship matrix in report  (Read 3014 times)
Mario Wens
« on: March 31, 2011, 06:34:30 pm »
We are currently describing the proposed redesign of an existing system, and have mapped the architectural features on the proposed Use Cases, the needs on the features etc., resulting in a number of relationship matrices. We now want to incorporate these into a report template so we can generate a complete rtf-documentation. The problem we encounter is that a relationship matrix is not an element in a package in the Project Browser, so not anything the report generator recognizes.
The rather unwieldy method we now use is as follows:
- generate each matrix as a PNG-file
- create a Package in the Project Browser
- create a linked document for the package
- paste each PNG-file into the linked document
- edit the rtf-template in such a way that it includes the linked document
- generate the document
This works, but the slightest change in any relation means the matrix has to be re-generated as a PNG and replaced in the linked document before you can generate a newer version of the document. This means having to maintain changes in two different places in the model.
Is there an easier way to incorporate relationship matrices in documentation?
« Last Edit: March 31, 2011, 06:35:48 pm by mariow »
philchudley
Re: Relationship matrix in report
« Reply #1 on: March 31, 2011, 07:19:56 pm »
Not at the momment, the way you suggest is exactly how I produce Matrix documentation.  :(
However, direct output of Relationship Matrix IS supported in the upcomming Version 9.0 - it certainly works in the current Version 9.0 Beta 1 release.
I do know of at least one user who re-created the Matrix using Element Connectors in the RTF template ...
Cheers
Phil
Models are great!
Brian Doty
« Reply #2 on: May 30, 2011, 04:55:16 am »
Hi Phil -
What do you mean by "direct output" of the relationship matrix?  I've looked in Version 9 and am unable to find what you are referring to.
Personally, I would love to add a "matrix" to the package browser.  This matrix would be preset with the source and target, directionality, stereotypes, etc and would automatically be generated as documentation reports are generated.
-B
philchudley
« Reply #3 on: May 30, 2011, 08:10:03 am »
In the RTF template editor for EA version 9.0, there is a checkbox for Relationship Matrix under the Package checkbox.
Not sure how it "picks up" the relationship matrix, I have tried this but I only seem to get one relationship matrix per package, even if a package is used as source or target in more than one matrix each saved as a profile
I'll keep trying
Cheers
Phil
Models are great!
