Author Topic: Requirements Traceability  (Read 3075 times)
ngong
« on: June 20, 2011, 10:40:14 pm »
 I have got two models behaving different and I like to know why:
 It is about Reruirements, Use-Cases, and Components.
 In a diagram I have connected a Use-Case to some Requirements using a Realization association. In another diagram I connected a Component with a Use-Case also using a Realization association.
 In one model I can find the Requirements in the Tagged Values properties of the component, what is a needed service to me. It tells me, that the component is affected by this requirements.
 I did the same in another model but it does not have that trick. Could you think of, what could be different that hinders this Traceability service?
 Kind Regards
 Rolf
p.s. I am using EA 8.0.864
« Last Edit: June 20, 2011, 10:45:55 pm by ngong »
Rolf
Dave_Bullet
Re: Requirements Traceability
« Reply #1 on: June 24, 2011, 01:43:15 pm »
Strict UML syntax turned on?  Not sure if this is at the tool (EA) level or per repository?
« Reply #2 on: June 24, 2011, 05:45:48 pm »
Probably an MDG setup issue when tagged values behave different.
