Author Topic: Mapping based on a connector  (Read 2187 times)
MV
« on: July 12, 2011, 11:53:22 am »
did not get any suggestion of previoous posts on the same
I would like to know how business rules are implemented in UML Modeling using EA. I have set of business rules as requirement type elements. One example is
< 'Transaction Id' must be unique and no transaction with the specified Transaction Id must have already been processed by the system >
I am using  Instruction->Data Element Mapping  kind of appraoch  where multiple instructions make a transaction.
I am creating a mapping diagram between instruciton and data members that will be used for the instruciton.My instruction and data elements noth are info type elements. I am simply using a dependency connector between them but here want to asociate my business rules to this connector as follows-
1 - This business rule should be displayed on diagram on the connector
2 - There should be traceability for the busines rule for connector...
Is this possible ?
RoyC
  • Read The Help!
Re: Mapping based on a connector
« Reply #1 on: July 12, 2011, 01:49:15 pm »
Have you read about Business Rules in the EA Help? Do those facilities help you at all?
Best Regards, Roy
