Author Topic: sql query problem  (Read 3543 times)
jagang
sql query problem
« on: August 10, 2011, 02:56:31 am »
hi,
I try now several hours to execute the following sql query within Repository.SQLQuery(sql) Method:
SELECT AVG(Stereotypes) AS AVGStereotypes FROM (SELECT c.Package_ID, COUNT(c.Stereotype) AS Stereotypes FROM t_object c GROUP BY c.Package_ID HAVING COUNT(c.Stereotype) > 0)
I just want to get the average count of stereotypes for a package within the project. The SQL Syntax should be right but I always get the error: DAO.QueryDef[3131] Syntax error in FROM clause.
Even if I try such simple sql queries like "SELECT Package_ID FROM ( SELECT Package_ID FROM t_package )" or "SELECT a.Package_ID FROM ( SELECT Package_ID FROM t_package ) a" I receive the same error message.
Is there something I did wrong?
greetings alex
Re: sql query problem
« Reply #1 on: August 10, 2011, 05:12:04 pm »
Yes, Access (and especially the DAO implementation used to access Access) doesn't like anything fancy like subqueries.
Why do use these subqueries at all?
What's wrong with "select Package_ID from t_package" iso "SELECT Package_ID FROM ( SELECT Package_ID FROM t_package )"?
OpenIT Solutions
« Reply #2 on: August 10, 2011, 10:03:31 pm »
Stereotype is a text field in t_object so you would need to do a unique count of stereotype per package then average the result. The sql would look something like this:
SELECT avg (package.packageCount) FROM (SELECT count (stereotype) AS packageCount from t_object group by stereotype, package_id) AS package
However this gives an error - not sure why, ill post again when i figure it out...
OpenIT Solutions
« Reply #3 on: August 10, 2011, 10:05:16 pm »
Sorry mis read your sql - which as you say should work - not sure what the issue is...
