Author Topic: Customer Requirements Properties  (Read 6130 times)
Zafi
« on: December 09, 2011, 04:23:49 am »
Hi
We are using EA for requirements gathering, is there a way we can add custom properties to requirements tab i.e.  currently the properties tab in requirement has "Short Description", Alias, Status, Difficulty, Priority etc, however we need more data fields like "Tier 1 Owner", "Tier 2 Owner", etc..
My question: Is it possible to do this in EA and if so how.
Cheers
Graham_Moir
Re: Customer Requirements Properties
« Reply #1 on: December 09, 2011, 05:00:55 am »
Sounds like "Tagged values" is what you are looking for.
philchudley
« Reply #2 on: December 09, 2011, 05:36:37 am »
Absolutely! Tagged values are the way to go!
Even better, create a stereotyped requirement in a profile which contain the tagged values, and then the bespoke requirement is available and tagged values can be applied retrospectively
Saves added all the tags one-by-one to every requirement!
Cheers
Phil
Models are great!
Zafi
« Reply #3 on: December 09, 2011, 05:59:13 am »
Thank you both,
Where can I find more information on creation of steriotype requirements and other functions related to steriotype requirements such as quring linking reporting, validation etc.
« Reply #4 on: December 09, 2011, 08:50:36 am »
You should consider writing an MDG so you can create stereotyped elements along with their respective tags. A little tutorial can be found here.
