Author Topic: Error - Modeling an ArcGIS geodatabase with EA  (Read 3809 times)
daniel_DNL
« on: January 17, 2012, 12:15:43 am »
I'm going to use Enterprise Architect to create an ArcGIS geodatabase. Before that I tried to practice on a tutorial (http://www.sparxsystems.com/resources/demos/arcgis/arcgis-ea-intro.htm).
Im following it step by step, but at the end (while importing the XML workspace document to ArcCatalog 10) an error occured: "Import xml data failed, FDO Error -2147186428 {Line: 364, column: 23]
When I looked into the source code of the generated xml file I found that the line 364 presents ending text of the WorkspaceDefinition.
I would be very gratefull if you could give me some advices and help to solve this problem.
« Last Edit: January 17, 2012, 12:19:33 am by danielDNL »
Re: Error - Modeling an ArcGIS geodatabase with EA
« Reply #1 on: January 17, 2012, 07:39:35 pm »
I have clue. Where do you get the xmi from?
daniel_DNL
« Reply #2 on: January 20, 2012, 09:26:22 pm »
Im just following the tutorial. So I exported my project from EA using Extensions-->ArcGIS-->Export to ArcGIS Workspace XML. And then I tried to import the xml file (the result of the export process) to ArcGIS
« Reply #3 on: January 20, 2012, 10:30:33 pm »
If so you should report that as a bug to Sparx.
daniel_DNL
« Reply #4 on: January 20, 2012, 11:07:24 pm »
I did it. And that's what they answered me
"Thank you for your report.
We have been able to reproduce the scenario described in your report and
this will be investigated further by our development team.
Your reference number for this issue is xxxxxxx.
Unfortunately we cannot provide any schedule for this issue to be
resolved as yet. If you wish to request the status of this issue at a
later time, please quote the above reference number in your enquiry.
Best regards"
I was hoping that maybe someone else had the same problem and thats why I decide to write about it here also..
Maybe you could see the xml file which I exported from EA and check it?
« Last Edit: January 20, 2012, 11:10:56 pm by danielDNL »
« Reply #5 on: January 21, 2012, 02:21:28 am »
Sorry, but that's not my domain. Maybe someone else?
