Author Topic: Problem: Generate Java Code from Class Diagram  (Read 3037 times)
Ahuga
« on: January 26, 2012, 09:51:12 pm »
After importing some java Classes I have the perfect java code in the UML Classdiagramm.
Using the default Code Templates to generate Code, it's not usable Code anymore because of the import statements:
original:
import org.apache.commons.lang.builder.CompareToBuilder;
import org.drools.planner.api.domain.entity.PlanningEntity;
import org.drools.planner.api.domain.variable.PlanningVariable;
import org.drools.planner.api.domain.variable.ValueRangeFromPlanningEntityProperty;
import org.joda.time.DateTime;
generated:
import model.Shift;
import model.Employee;
import model.UserFacts;
import model.ShiftType;
I just would like to have the same code - can be compiled - generated as I have imported. I guess I have to make some changes in the Code Templates.
But how does this script language works?
Thanks a lot for help.
