Author Topic: Show class properties in RTF Report  (Read 2386 times)
Kevin Escalera
« on: March 21, 2012, 03:33:10 am »
Hi everyone, I'm tryng to generate an RTF report that lists my Class Model, I created a template based on the Basic template, but I'm having trouble with showing the properties defined for my classes, I can get attributes, relationships and methods, is there any way to get the properties in the template??
philchudley
Re: Show class properties in RTF Report
« Reply #1 on: March 21, 2012, 06:45:05 am »
By properties are you referring to TaggedValues?
If so, then there is a checkbox labelled [highlight]Tagged Values[/highlight] under the Elements checkbox in the RTF Template editor. This will output ALL tagged values for the class (or element).
To output a specific tagged value Insert a field for the element and choose [highlight]valueOf[/highlight]
You will then be prompted for the name of the tagged value, enter it exactly as defined and you will see its value in the RTF output.
Hope this is clear
Cheers
Phil
Models are great!
Kevin Escalera
« Reply #2 on: March 21, 2012, 07:27:25 am »
I was actually talking about the structure of the class: for example:
Class: Person
has a field : _name
read/write property: Name
    public class Person
        string _name;
        public string Name
            get { return _name; }
            set { _name= value; }
When I use the basic template of the RTF reports I only see the field _name, but I cannot see the property Name
