Author Topic: Recursive Query for Package Tree Contents  (Read 11122 times)
Luc De Graef
« on: July 13, 2011, 09:12:27 pm »
I am using EA-8 with a SQL Server based repository.
I want to extract information related to elements in a package and in lower packages.
For this purpose I need to determine all packages in a specific tree.
A hard-coded query (going only 2 levels deep) is
select t_package.Name Package, t_package.Package_ID, t_package.Parent_ID
from  t_package where
  t_package.Package_ID in (select  t_package.Package_ID from  t_package where t_package.Name = '00-000 F Information')
or t_package.Parent_ID in (select  t_package.Package_ID from  t_package where t_package.Name = '00-000 F Information')
 where t_package.Parent_ID in (select  t_package.Package_ID from  t_package where t_package.Name = '00-000 F Information')
But this is of course not scalable.
Can one use some kind  of Recursive Query syntax? Does anybody have an example?
Luc
Re: Recursive Query for Package Tree Contents
« Reply #1 on: July 13, 2011, 09:49:10 pm »
Luc,
You can't use recursive queries in EA (I tried it when we upgraded from SQL Server 2000 to 2008)
But your query doesn't seem optimal.
I would do something like:
select * from t_object o
join t_package package1 on o.package_id = package1.package_id
left join t_package package2 on package2.package_id = package1.parent_id
left join t_package package3 on package3.package_id = package2.parent_id
left join t_package package4 on package4.package_id = package3.parent_id
left join t_package package5 on package5.package_id = package4.parent_id
left join t_package package6 on package6.package_id = package5.parent_id
left join t_package package7 on package7.package_id = package6.parent_id
left join t_package package8 on package8.package_id = package7.parent_id
where
package1.name = 'MyPackageName'
or package2.name = 'MyPackageName'
or package3.name = 'MyPackageName'
or package4.name = 'MyPackageName'
or package5.name = 'MyPackageName'
or package6.name = 'MyPackageName'
or package7.name = 'MyPackageName'
or package8.name = 'MyPackageName'
This returns all objects in the package with the name "MyPackageName" and all its subpackages for eight levels down.
Add levels as you see apppropriate.
If you want a "real" recursive solution, you'll have to go with an add-in search.
« Reply #2 on: July 14, 2011, 09:38:17 am »
If you're writing a custom sql search, try the #Branch# substitution.
« Reply #3 on: July 14, 2011, 04:05:30 pm »
Simon,
%Branch% gives you the id's of the packages directly under the selected package (and not deeper), so I don't think that is really what Luc was looking for.
« Reply #4 on: July 18, 2011, 08:18:08 am »
You may read that from the documentation, but the purpose of it was for a full recursive list of package ids.
Have you tried it?
RoyC
  • Read The Help!
« Reply #5 on: July 18, 2011, 10:01:20 am »
To remove that ambiguity, I have changed the description to:
- gets the IDs of the child packages of the currently-selected package, working recursively down to the lowest level of sub-package
in the Create Search Definitions topic.
Best Regards, Roy
stevesavage
« Reply #6 on: April 19, 2012, 01:40:17 am »
For Oracle the search would be:
select  package_ID from t_package start with ea_guid = '{9F54BF3D-0F7A-4ec7-979C-7001A37FF9FC}' connect by parent_ID = prior Package_ID
Where the ea_guid is the GUID of the parent package.
For SQL you could try (untested):
WITH recursiveQ(Package_ID) AS (SELECT Package_ID FROM t_package AS parent WHERE ea_guid = '{9F54BF3D-0F7A-4ec7-979C-7001A37FF9FC}' UNION ALL SELECT child.Package_ID FROM recursiveQ AS parent, t_package AS child WHERE child.Parent_ID = parent.Package_ID) SELECT Package_ID FROM recursiveQ
Sorry I don't have an SQL server to test this with, the version is based on info found at: http://www.ibm.com/developerworks/data/library/techarticle/dm-0510rielau/
stevesavage
« Reply #7 on: April 19, 2012, 01:43:48 am »
@Geert, don't know why the SQL version doesn't work. the Oracle version works perfectly.  Is it an EA problem or the default permissions on the server?
A possible work around would be to set a tagged value for all elements in the package to indicate the "root" package, and then only include elements with that tagged value.
