Author Topic: Simulation & BPMN Gateway  (Read 3997 times)
Tim Twe
« on: May 11, 2012, 06:17:11 pm »
I am trying to simulate a BPMN process diagram from the example project (Analysis & Business Models / Process Diagrams / Sub Process Activity) and it works great until it gets to a Gateway node.
How do I get the simulation to choose one path over the other?
The examples are not clear OR I am blind.
-Timothy
Tim Twe
Re: Simulation & BPMN Gateway
« Reply #1 on: May 12, 2012, 01:44:15 am »
I cannot seem to assign one path (or the other) a "trigger".
Any advice/insight would help greatly.
Sequence diagrams and state diagrams work perfectly.  UML Activity diagrams seem to fail aswell.  I'd expect to see the [constraint] as the highlighted trigger in the Waiting Triggers section.
« Reply #2 on: May 14, 2012, 03:31:32 pm »
Hi Tim,
it's the ControlFlow (SequenceFlow) that determines the exit of the Gateway.
Make sure your constraint is implemented as the correct "pseudocode" in the ConditionExpression for the ConditionType "Expression".
