Author Topic: Embed or attach a document into model  (Read 13341 times)
Boron
« on: June 04, 2012, 06:27:02 pm »
I searched a lot in the board but I could not find an answer to my question (neither a positive nor a negative answer):
How can I embed or attach a document into the model?
The document may be a Excel or Word document or anything else.
I am thinking a mechanism just like an email attachment. The file is stored inside the model and when double-clicking it opens in the intended tool for editing.
I an diagram I could set a hyper-link to an external storage location to the document. But as the storage location is not fixed a storage inside the model would be great.
All I can find is that I can embed RTF files, but I have an Excel document.
Any ideas or is it impossible?
Thanks a lot
Michael
RoyC
  • Read The Help!
Re: Embed or attach a document into model
« Reply #1 on: June 05, 2012, 09:42:17 am »
Use a linked document. You can also associate elements with files (the Files tab of the element Properties dialog).
Best Regards, Roy
Boron
« Reply #2 on: June 06, 2012, 05:52:49 pm »
No chance of storing a file inside the model?
Your suggestion stores the file somewhere on the file system and simply refers to it from the model.
RoyC
  • Read The Help!
« Reply #3 on: June 07, 2012, 09:21:56 am »
A linked document is internal to EA and can contain an RTF or a CSV (Excel) file. You can attach them to a range of types of element, or you can create a Document Artifact element that represents the linked document itself, and that opens the document directly when you double-click on it.
An Artifact element can represent files from a wider range of types, which might exist external to the model. However, if you press Ctrl+E on the element it directly opens each file for editing, which satisfies one of your requirements.
Does that get you any further ahead?
« Last Edit: June 07, 2012, 09:28:56 am by RoyC »
Best Regards, Roy
« Reply #4 on: June 07, 2012, 02:21:26 pm »
See http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/modeling_basics/linking_documentation.html
Note that actually the only document format that can be stored is rich text format.
To an extent you can kludge this by embedding a spreadsheet, visio document, image, or pdf within a word document and saving as RTF, but its not really satisfactory.
See
9.0 Linked documents (new formats)
Embed PDF files
« Last Edit: July 03, 2012, 12:23:18 pm by skiwi »
