Author Topic: Transfer images between repositories  (Read 6424 times)
adepreter
« on: May 11, 2012, 11:08:56 pm »
Is there any way to easily...
- Export selected images from a Repository A, and then
- Import these images in a Repository B?
Alain
Makulik
Re: Transfer images between repositories
« Reply #1 on: May 12, 2012, 12:46:02 am »
I think using 'Project->Model Import/Export->Export Reference Data' and selecting 'Model Images' should do the job. Vice versa for import ...
Edit:
Aah, I've overseen 'selected images' in your question, not so sure if you can select particular images before exporting them.
Günther
« Last Edit: May 12, 2012, 12:47:49 am by Makulik »
« Reply #2 on: May 12, 2012, 12:49:17 am »
You can't. Only after exporting them to XML you can edit the XML and delete the superfluous ones.
William McKenzie
« Reply #3 on: June 08, 2012, 07:32:11 am »
So is there any access to this functionality at all in the Automation API? Can I call the 'export/import reference data' functions from a script or AddIn?  I don't see any way to do it off hand.
« Reply #4 on: June 09, 2012, 12:49:52 am »
I haven't see that too. Funny though as it is quite easy to create the export via the right SQL query which by the way already delivers XML. So it's quite simple to create the desired output format.
