Author Topic: Help: Ports and Interfaces 2  (Read 2858 times)
StevePinfold
« on: September 20, 2012, 01:41:55 am »
Hi All
I wanted to tap in on all of your experience as I can't find the correct way to model a particular issue ... thanks in advance for reading.
I have a system with a number of I/O lines (signal A, signal B etc) and a multi-port I/O card (Port A:0 - 7, Port B: 0-7 etc) and I am working in the component model.
I wish to generate a diagram which allows me to create an I/O card component and then add each bit of each port. I then wish to link each signal to a specific I/O Port, for example
 Port A Bit 3 - Signal A
 Port B Bit 2 - Signal B
I can draw the diagram and feel happy with this, but when I generate the document I would like to see a table somewhere that says
 Port A Bit 0
 Port A Bit 1
 Port A Bit 2
 Port B Bit 0
 Port B Bit 1
Hence describes my I/O mapping in both diagram and document.
Can anybody reccomend how I achieve this please as I'm running out of ideas of how to achieve this
Steve
« Last Edit: September 20, 2012, 02:00:35 am by StevePinfold »
Re: Help: Ports and Interfaces 2
« Reply #1 on: September 20, 2012, 04:33:04 am »
You should consider looking into SyML. For the time being you could model the signals via Information Flow conveying according classes representing the signal.
