Author Topic: Windows 7 64 bit Compatibility  (Read 6544 times)
pakcom
« on: November 14, 2012, 07:52:51 pm »
Hello all,
I want to ask about EA compatibility on Windows 7 64 bit.
Company where I work for now is planning to move to Win7 64 bit.
Our EA version is 8.0.862.
We also have several Add-Ins which we built by ourselves.
Does this EA (all features and Add-In) can work properly on Win7 64 bit?
Thank you.
_Simson
Makulik
Re: Windows 7 64 bit Compatibility
« Reply #1 on: November 14, 2012, 08:06:33 pm »
Works fine for me!
Günther
pakcom
« Reply #2 on: November 14, 2012, 08:08:42 pm »
Hi Günther,
May I know which EA version do you use?
Thanks..
« Reply #3 on: November 14, 2012, 08:10:58 pm »
8.0 is getting old already, so I would suggest to upgrade anyway, but I don't think there are any 64 bit compatibility issues. (it just runs in 32 bit)
Makulik
« Reply #4 on: November 14, 2012, 08:15:56 pm »
I'm using 9.3 (10 beta), but as Geert mentioned Version 8.x shouldn't give any problems either.
Aaron B
« Reply #5 on: November 15, 2012, 09:48:27 am »
Enterprise Architect 8 and above have been tested under Windows 7 64-bit edition without any issues.  EA is a 32-bit application but automatically runs under a compatibility mode with the 64-bit edition of Windows 7.
bosch
« Reply #6 on: November 24, 2012, 12:40:46 am »
I had a problem setting up Version Control Settings with Subversion and  EA9.3 on win7 64bit pc.
In particular if I copy svn.exe command line client in "C:\Program Files (x86)\" directory and I select "Subversion Exe Path" accordingly, when I try to Save, EA stucks until the connection timeout.
Another issue regards ODBC Drivers version to connect to an RDBMS EA Project.
I experienced that with an EA project on MySQL DBMS you have to use 32bit ODBC Drivers on a win7 64bit pc.
The trick is that if you want to create the "User DSN" to set the db connection using those drivers you have to run C:\Windows\SysWOW64\odbcad32.exe instead of default ODBC window in control panel
