Author Topic: Add trigger directly to element  (Read 3849 times)
Jos Fries
« on: January 05, 2013, 09:24:53 pm »
In EA version 9.2 I was able to add a Trigger directly to an element by selecting Add Element in the  Project Browser package context menu.  I thereto had to select <default> as the active toolset and then I was able to select a Trigger as the type of the new element.
In version 10 the default toolset seems to be UML::Class and there seems to be no way to select all available UML types. Furthermore, the Trigger type is - as far as I can see - no part of any toolset.
So, how do I add a trigger directly to an element in version 10?
Re: Add trigger directly to element
« Reply #1 on: January 07, 2013, 06:23:24 pm »
I have noticed that too when trying to add a collaboration. It used to be possible to select no toolset; which resulted in a flat list of all possible UML elements.
It took me a while before I found the correct toolset to use.
RoyC
  • Read The Help!
« Reply #2 on: January 08, 2013, 10:01:24 am »
This might require further investigation. Could you submit a bug report to Sparx Support please?  Thanks.
(BTW Geert, you can get Collaboration elements through the Use Case and Communication toolsets.)
Best Regards, Roy
Jos Fries
« Reply #3 on: January 13, 2013, 07:29:10 pm »
I just registered a support request. (That took some time as I had an issue with share-it in renewing my subscription.)
Jos
