Author Topic: Manage Baselines / Version Control  (Read 15190 times)
Gary
Re: Manage Baselines / Version Control
« Reply #15 on: January 24, 2013, 10:15:06 pm »
In the interest of completing this discussion, and just in case someone comes along later and wants to implement a solution, I spent 20 minutes trying out the code to create a baseline.  I played with two different ways of creating the baseline:
1) create a baseline for each package that sits just under the model package.
2) create a baseline for the package containing a diagram when it is closed. NOTE: this is everytime it is closed whether any change is made or not.
I have included the functions below.
       public void EA_FileClose(EA.Repository Repository)
                      //get a colection of models in the repository
                       foreach (EA.IDualPackage p in Repository.Models)
                           //get a collection of next layer package in the model
                           // and create abaseline for each of them using the current date and time as a version
                           EA.IDualCollection c = p.Packages;
                           foreach (EA.IDualPackage Kid in c)
                               Repository.GetProjectInterface().CreateBaseline(Kid.PackageGUID, DateTime.Now.ToString(), "");
            return;
        public void EA_OnPostCloseDiagram(EA.Repository Repository, int DiagramID)
            //get a diagram object identified by the ID
            EA.IDualDiagram diag = Repository.GetDiagramByID(DiagramID);
            //get the parent package object that contains the diagram
            EA.IDualPackage p = Repository.GetPackageByID(diag.PackageID);
            //create a baseline for the package containing the diagram just closed using current date and time as a version
            Repository.GetProjectInterface().CreateBaseline(p.PackageGUID, DateTime.Now.ToString(), "");
            return;
Enjoy
Gary ;)
« Reply #16 on: January 25, 2013, 12:30:01 am »
FWIW: creating a baseline means the creation of a whole XMI dump stored in the DB. If you have EAP files note that they are "not optimized" for large data volumes. In case of a server site repository you will notice a remarkable slow down when closing EA. Further your reference data are not in synch with the baseline because they are not part of it.
Stoppy
« Reply #17 on: January 29, 2013, 04:29:05 pm »
if you are working with limited ressources in environment and budget, I assume your number of developers is also limited.
Thanks for your input stefan, Yeah I have nothing available in developers. If you have 40 developers using a manual process, that's pretty good. I could imagine the solutions and suggestions to automate...... ;D
Thanks Gary, appreciate the follow up, if only I could read and understand the matrix aka "The Code" ;D
Thanks qwerty, I orginally wondered where this XMI file was going as there is a little dialogue box which pops up and has a temp path.
Stoppy  :D
Skills: Business Process | Business Analysts | Product Configuration Manager | Business Intelligence
