Author Topic: How to generate Data Model diagram from MySQL data  (Read 8340 times)
zhikzhik
« on: February 06, 2013, 10:32:25 pm »
I have made tables in MySQL database.
Can you please tell how to use  EA to generate DB diagram  Data model ?
« Last Edit: February 06, 2013, 10:32:56 pm by zhikzhik »
Re: How to generate Data Model diagram from MySQL
« Reply #1 on: February 06, 2013, 10:44:34 pm »
Right click on package Code Engineering|Import DB Schema from ODBC...
zhikzhik
« Reply #2 on: February 08, 2013, 01:40:22 pm »
Hi, I'm still not clear.
I have just installed EA.
How do I get to package Code Engineering ?  Where do I find it ?
« Reply #4 on: February 08, 2013, 03:05:26 pm »
Right Click on a Package, then select the option Code Engineering from the context menu...
zhikzhik
« Reply #5 on: February 08, 2013, 08:30:10 pm »
I am using   EA  V6.1
Here is what I did .....I   made a  new  EAP project ....then on Data Model ...right click > Code Engineering > Generate DDL schema from ODBC....I have been able to import DB Schema from MYSQL database  by this approach.
How do I generate Data Model diagram now ? I want  all tables in  a diagram with relationships. How do I get it ?
« Last Edit: February 08, 2013, 11:30:06 pm by zhikzhik »
« Reply #6 on: February 08, 2013, 11:05:43 pm »
I am using   EA  V6.1
Ah, there's your problem ;D
Why would you want to generate a diagram? Just create a diagram and drag the tables you want to show onto it.
zhikzhik
« Reply #7 on: February 08, 2013, 11:39:49 pm »
yup. I like it....can I drag all tables at one go ...something like "select all" and "drag all"  ...how do I do this ?
Also does the tables preserves the foreign key table relationships in diagram ?  If  not how do I show relationships in the diagram ?
Thanks .
« Last Edit: February 08, 2013, 11:50:59 pm by zhikzhik »
« Reply #8 on: February 09, 2013, 04:13:35 am »
multi-select and then drag
« Reply #9 on: February 11, 2013, 01:48:58 pm »
To be honest I'm not sure that version 6.1 had the capability of multi-select in the project browser. It did have a command 'Insert Related Elements' that will help though.
« Last Edit: February 11, 2013, 01:49:31 pm by simonm »
« Reply #10 on: February 11, 2013, 02:13:08 pm »
He should be OK...
Release Notes for EA 4.50 Build 740
Added support for multi-select drag and drop and delete in Project View
