Author Topic: StateMachine->Transition properties->Effect field  (Read 4096 times)
fox75
« on: February 12, 2013, 12:35:30 am »
somebody knows why there is such restriction on the size of the text that can be added to this field (StateMachine->Transition properties->Effect) ?
And if you add more you will have a DAO.Field[3163], the worst is that after this warning you can enter and you will see the full text (probably in a cache), but when closing and opening again the project the "additional" text is disappeared.
Is it possible do something to be able to write more ?
Helmut Ortmann
Re: StateMachine->Transition properties->Effect fi
« Reply #1 on: February 12, 2013, 01:17:17 am »
the lengt of the database field is 255 Bytes (t_connector.pdata3).
I don't think SPARX will change the database.
It's a good idea to post a bug report. Maybe they change the behavior.
Kind regards,
Helmut
