Author Topic: query for specific tagged value  (Read 8066 times)
megaman
« on: May 06, 2009, 04:59:06 am »
is there a way to ask an element for a specific tagged value? can we do such things as conditional statements in the RTF template? such as
if(element == usecase) ...
otherwise, how to separate use cases from other elements? i would like to do something like
Usecase
Requirements from this UseCase
Dermot
Re: query for specific tagged value
« Reply #1 on: May 06, 2009, 03:17:25 pm »
I would suggest you look at the RTF filtering available in the latest version.  For more information see the section on filtering in the RTF whitepaper.
megaman
« Reply #2 on: May 08, 2009, 09:30:03 am »
sorry i should have been more clear.
for example, i have a use case.  it has connectors to the requirements it realizes, and one connector to the actor of the use case.
i only want to print the requirements associated with the use case.  but the template only allows me to get all the connector->target->elements, not just some of them.
how would i only print the requirement targets for this use case?
megaman
« Reply #3 on: May 08, 2009, 09:32:20 am »
also, this is being generated in a model document.  this model document already has a filter set on it to return all use cases.  what i need now is a way to filter parts of the template or do some conditional expression while the template 'iterates'.
is this possible??
Dermot
« Reply #4 on: May 08, 2009, 04:04:00 pm »
In the latest Version: F8 | Options -  allows filtering by Connector type and direction.  This should allow differentiation between the Actor and the Requirements by setting the direction and type='Realization'.
megaman
« Reply #5 on: May 09, 2009, 10:49:57 am »
so far that doesn't seem to have any effect.  I excluded all connectors and i still get the same result.
on another note, here's an interesting result: i created a dummy requirement in a use case. i trace it to another requirement. via Relationship matrix.  when i print the dummy requirement out, i am printing its connector->target->element->name.  I get the right dummy requirement parent.  But I also get the dummy requirement itself.  what's the meaning of this? :o
« Last Edit: May 09, 2009, 10:52:46 am by wuth »
Dermot
« Reply #6 on: May 11, 2009, 11:33:09 am »
Reagrding your first point;  this option does work - I am not sure what you have done to get this.
Second Point: The Connector source and target both need to be displayed. It is best o use a table for this.
megaman
« Reply #7 on: May 12, 2009, 06:26:24 am »
i tried generated from the model directly and the exclude Connector options seem to apply.  However, using virtual documents F8 | Options seem to be ignored.  How can we have model documents exclude connector types?
« Last Edit: May 12, 2009, 08:11:30 am by wuth »
megaman
« Reply #8 on: May 12, 2009, 09:20:47 am »
i've also observed the following:
use case is connected to (points to)  requirement A.
requirement A is connected to another requirement B.
when printing connector->target->element->name for requirement A,
you get:
Requirement A
Requirement B
Requirement B is the only REAL target for requirement A.  But Requirement A is the target of the Use Case.  Why does EA not distinguish between these two cases?  Does it simply look at all Connectors involving Requirement A and publish the targets without first checking to see if Requirement A is the source?
« Last Edit: May 12, 2009, 09:26:53 am by wuth »
Dermot
« Reply #9 on: May 12, 2009, 05:15:51 pm »
Regarding reply#7 - The filtering is set permanently for each individual Template in the RTF editor: File | Document Options.  It is best to use this especialy for each Model Document.
Reply #8: It is necessary to use both the connector::target::element and the connector::Source::Element fields - what you are reporting are only the targets  - these can differ depending on how they were originaly set.
megaman
« Reply #10 on: May 13, 2009, 12:33:19 pm »
thanks dermot.
using your suggestion for reply #7 was very helpful, i was able to only ask for the target elements by setting the direction to source->target.  when would you ever have target->source?
Krzysztof Swiatkowski
  • Understanding is a three-edged sword
« Reply #11 on: May 16, 2009, 06:59:05 am »
In case of requirements why can't you use template section Package::Element::External requirements ?
It should do the trick and allow you to print requirements realized by use case?
Regards
Kris
If I put you finger in the eye
then you have finger in the eye
and I have finger in the eye
but it's not the same
megaman
« Reply #12 on: May 16, 2009, 07:34:49 am »
kris,
good idea, that would work too.  i only tried it this way because i thought it would let me be a little more flexible on some filtering i wanted to do.
i was hoping there was some way to do filtering on requirement type from within the external requirements tag.  but this doesn't seem possible
