Author Topic: Forum  (Read 24614 times)
g.makulik
Re: Forum
« Reply #15 on: July 23, 2013, 07:04:27 am »
[edit]OK! I have used the 'Mark all as read' button at the lower right side on the 'Discussion' board now. Let's see if this lasts then.[/edit]
Seems to work right now ...
Re: Forum
« Reply #16 on: July 23, 2013, 07:21:45 am »
Nope. I used the top button and now tried the bottom one. Both work the same wrong way. The current section is marked read. But all other sections turn into unread >:(
g.makulik
Re: Forum
« Reply #17 on: July 23, 2013, 04:04:46 pm »
You're right! As soon I use the button inside a section, all other sections will go unread again. >:(
« Last Edit: July 23, 2013, 04:06:45 pm by g.makulik »
RoyC
  • Read The Help!
Re: Forum
« Reply #18 on: July 23, 2013, 04:27:35 pm »
We are aware of this and are looking into it.
Best Regards, Roy
Re: Forum
« Reply #19 on: July 23, 2013, 08:24:56 pm »
Thanks!
g.makulik
Re: Forum
« Reply #20 on: July 24, 2013, 09:10:32 am »
Just to give you some more of my observations:
When I'm here http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?catselect=general and click 'Mark all as read', the next upper level (http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi) pops up and shows all posts in 'Latest News' section as unread. Choosing 'Mark all as read' inside 'Latest News' will set all messages in the discussion boards to unread in turn.
Best regards,
Günther
Re: Forum
« Reply #21 on: July 26, 2013, 01:14:56 am »
Is there any timescale? I mean looking into is nice. But what I really need is a solution.
Re: Forum
« Reply #22 on: July 26, 2013, 08:59:49 am »
Workaround of marking as read at the top level? (I have nothing to do with Forum maintenance, but I have found that marking as read like that works)
Re: Forum
« Reply #23 on: July 26, 2013, 10:35:20 am »
That works (around). Please, if you have this fixed or know when, post it here.
Doug Blake
Re: Forum
« Reply #24 on: August 08, 2013, 01:13:44 am »
Has this been fixed, its still happening to me!!!!! ARRRGGHH
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
g.makulik
Re: Forum
« Reply #25 on: August 08, 2013, 09:48:39 am »
Apparently not!
It just requires some discipline to handle:
Never mark 'All Read' in forum boards, just ignore the threads you want to ignore when you're there. After reading all boards of interest, mark them all as 'All Read. This will show the next upper board level as unread then. Mark 'All Read' again. Now if you're updating the page, you'll see only new or updated threads again.
Günther
Re: Forum
« Reply #26 on: August 08, 2013, 07:36:55 pm »
At least the search now works (though they obscure it by adding more and more fake search buttons, fields and links to the page). However, I have no idea what motivation Sparx drives :o
« Last Edit: August 08, 2013, 07:37:13 pm by qwerty »
Re: Forum
« Reply #27 on: September 05, 2013, 08:01:01 pm »
Seems as if you're looking very intense. But where?
