Author Topic: Turn on AutoNum when transforming to DDL  (Read 5828 times)
Owl Saver
  • Never give up.
« on: May 07, 2012, 12:32:00 pm »
I am creating a domain model using the DDL transformation. I would like it to genrate all the keys with AutoNum turned on. I looked at the template and found the place where I think it should be done. But, I do not know how to specify the AutoNum property and what value to use to set it to true.
Below is the section from the template where I am trying to modify. My guess is I need to add a line like:
AutoNum = true
But, that does not work. Any help would be great.
%if elemType != "Association"%
  PrimaryKey
    Column
      name=%qt%%CONVERT_NAME(className, "Pascal Case","Camel Case")%ID%qt%
      type=%qt%%CONVERT_TYPE(genOptDefaultDatabase,"Integer")%%qt%
%endIf%
Thomas_Arnbjerg
Re: Turn on AutoNum when transforming to DDL
« Reply #1 on: January 29, 2014, 05:14:25 pm »
Did anyone know the answer for this? I have the same question.
Thomas_Arnbjerg
« Reply #2 on: January 29, 2014, 05:18:45 pm »
The solution is to patch the template 'class' in the DDL transformation with an autonumber element as shown below:
  PrimaryKey
    Column
      name=%qt%uniqueId%qt%
      autonumber
      Startnum="1"
      increment="1"
Owl Saver
  • Never give up.
« Reply #3 on: January 30, 2014, 12:20:39 am »
Thanks, I will give this a try.
