Author Topic: WAN Optimizer  (Read 6268 times)
jimbo
WAN Optimizer
« on: April 17, 2014, 06:02:30 am »
I found the WAN Optimizer setup file. I have also looked in the help file.
I would like to find the instructions for setting up the WAN Optimizer. I am sure I had copy a long time ago but I can't find it.
~J
~J
RoyC
  • Read The Help!
Re: WAN Optimizer
« Reply #1 on: April 17, 2014, 10:16:00 am »
Are you a registered user? If so, look here:
http://www.sparxsystems.com/registered/reg_ea_down.html#WanOptimizer
The user guide is available on the registered download page, right next to the product download.
(Thanks to Scott, the Sparx Communications Manager.)
Best Regards, Roy
Aaron B
Re: WAN Optimizer
« Reply #2 on: April 17, 2014, 11:19:25 am »
If you have installed the WAN Optimizer, there should be a copy of the user guide PDF file in the Admin subdirectory (E.g. C:\Program Files (x86)\Sparx Systems\WAN Optimizer\Admin).
You may also be interested to learn more about the new Cloud Services functionality being introduced in EA 11 which will provide further enhancements to the performance and security of connections over WAN.
http://www.sparxsystems.com/products/ea/11/index.html#deployment
jimbo
Re: WAN Optimizer
« Reply #3 on: April 18, 2014, 06:15:38 am »
Perfect I got it. Thank you for the guidance.
~J
jimbo
Re: WAN Optimizer
« Reply #4 on: April 19, 2014, 04:41:20 am »
If I install the WAN Optimizer do I still have the choice of connecting directly to db without the WAN Optimizer?
~J
~J
Aaron B
Re: WAN Optimizer
« Reply #5 on: April 22, 2014, 10:38:10 am »
Yes, you can still connect directly to the database from EA without specifying the WAN Optimizer.  The WAN Optimizer is not a replacement for the direct database connection.
