Author Topic: EA as an ALM tool  (Read 6087 times)
tibweb
EA as an ALM tool
« on: August 08, 2014, 12:19:50 am »
Hi everyone,
I am looking for some info about how to use EA in a corporate environment; e.g. the Ultimate version. I can see that it can manage requirements quite well even without UML, but to use it as a requirement manager tool there must be some more feature. I'd like to know if EA supports these.
For example
  • Create workflows (e.g. requirement shall not be added as approved without review and approval)
  • Create user groups per project
  • Customize who can do what (for example developer shall not be allowed to change requirement status to approved)
  • Automatic versioning of approved requirements
Is there some doc or video tutorial which would explain can I solve these thins or what workaround shall be used? Right now I am using the Professional version and I'd like to see how well we could use EA in a corporate environment as a single tool to cover ALM addition to design.
Thanks in advance,
// Tibor
Sunshine
  • Its the results that count
Re: EA as an ALM tool
« Reply #1 on: August 08, 2014, 08:29:24 am »
Haven't used it myself but I understand you might be able to do this via workflow scripts. Have a look in user manual and search for workflow scripts for more details.
Yes kind of. You can create groups to restrict who can do what and you can create a group to lock a project. So horizontal and vertical restrictions in one model repository (i.e. central model paradigm). You could create a repository for each project and create a user group for each repository. Not such a good approach if you want to share things across projects.
No but you could put the requirements in a package and apply a lock that just lets a group say "Business Analysts" edit elements in that package.
Not sure but it might be possible via workflow scripts. Hopefully someone else can answer this one.
Hope that helps  :)
Happy to help
tibweb
« Reply #2 on: August 11, 2014, 06:22:07 pm »
Thanks for the answer. I've some info based on what you told and most of the things may be solvable. Unfortunately I expected a little bit more ready made solution, but I need to dig further to see what I can do with scripting. Thanks again.
Sunshine
« Reply #3 on: August 13, 2014, 06:52:47 am »
Just a further thought. If you are approving requirements in bulk in a package then you can use the update package status feature. Right click on package>advanced>update package status. You get a dialog where you can update all the elements status and version at the same time.
Not sure if that helps, hope it does. :)
Happy to help
Dermot
« Reply #4 on: August 13, 2014, 11:49:14 am »
There is a whitepaper and an example model on working with Workflow scripting available on:
http://community.sparxsystems.com/white-papers/765-workflow-scripting-in-enterprise-architect
This should cover your first three points.
