Author Topic: Model validation  (Read 2507 times)
Thomas Kliegl
Model validation
« on: September 02, 2014, 09:53:54 pm »
I am using SysML and connected a block A to a Requirement using a satisfy connection.
Another block B ist connected to block A with a realize connection.
The model validation gives back a warning, that the Requirement is not realized.
Can't a Requirement be realized 'around the corner'?
Gary
Re: Model validation
« Reply #1 on: September 08, 2014, 06:34:30 pm »
Not so far as I have found. You could probably do it with an addin that follows the path based on connectivity rules. Personally I use a class to actually realise a block to show the shift between abstract(block) to more concrete(class). I also check that each requirement has either a satisfy or realise (there are exceptions of course) I also check that a requirement has a verify connection to a testcase. The connections can be checked by an sql search or an addin.
Gary
