Author Topic: Empty space in diagram when exporting  (Read 3433 times)
Rae
« on: September 18, 2014, 07:27:12 am »
Hi there
I'm trying to export diagrams from EA using SysML 1.2 technology. For some reason when exporting quite a lot of empty space is left in the picture of the the diagram, which is of no use.
Has anyone experienced a similar problem? And is there a  fix to it?
An example of the problem. Just that the empty space is usually way bigger.
Cheers
Rasmus
Re: Empty space in diagram when exporting
« Reply #1 on: September 18, 2014, 08:14:25 am »
Hi Rasmus, there were some recent discussions about additional space being exported. Maybe you're lucky finding them via the Search button top left. Else try the Google Sparx group which holds a shadow of this forum (and which finds faster and more accurate).
« Reply #2 on: September 18, 2014, 09:09:28 am »
I remember that issue: It was caused by EA mis-calculating the size of floating text labels in some circumstances. A change went through code review a while back but I don't know if it has made it into a release yet. (And, of course, I don't know what version of EA the OP is using)
« Last Edit: September 18, 2014, 09:10:22 am by KP »
Rae
« Reply #3 on: September 19, 2014, 12:23:09 am »
Maybe a fix has been released, i dont know really. I am using EA version 9.2.
I found a workaround though. Saving the images through the ctrl+T command solved the problem for me. Even though all other methods creates whitespace, ctrl+T havne't done it yet.
In case anyone is lost in the same annoying problem, you can try this.
Thx for replying both of you :)
Cheers rasmus
