Author Topic: repository issues  (Read 4784 times)
xhanness
repository issues
« on: August 12, 2009, 01:50:20 am »
I have been struggeling for two days with two issues:
ISSUE 1
1) I created "Microsoft Access Driver" in Windows data sources
2) The source is referencing an EAP in file on my disk
3) With use of Aqua data studio, I am able to connect this data source, but the schema is empty
:-/ I do not see any tables ... no data.
ISSUE 2
1) I created a schema on a MySql server and run the script provided by Sparx for creating all necessary tables
2) I set up a connection to the database in EA according to steps on Sparx web.
3) when I click open the project, there is a "Loading project" label in left bottom corner of the window. When it disappears, nothing happen - the project is not open.
Any hints are warmly welcome :)
PS: I have the Corporate edition
Mike Fechner
Re: repository issues
« Reply #1 on: August 12, 2009, 04:34:35 am »
Did you copy the eabase.EAP content to the empty DB using the project transfer wizard?
xhanness
« Reply #2 on: August 12, 2009, 05:01:03 am »
Hello Mike,
thanks for the right hint. Yes, I forgot to set up the new repository with an empty project. Now it works fine !  :D
However, if anybody have an idea how to solve the first issue ...
