Author Topic: How many chars EA supports as a "database field"  (Read 4627 times)
Hardy
« on: October 30, 2014, 12:52:47 am »
I am creating sequence diagram to reflect some of existing old systems. I use class as lifeline in the sequence diagram, I want to use actual functions as message between lifelines. I reverse the code into my class diagram to get classes first.
In my old systems, many of the functions have lots of parameters. When I select this kind of function as my message I got error message "Message data is too large for database field. Please shorten message parameters and retry."
So what can I do with it?
Re: How many chars EA supports as a
« Reply #1 on: October 30, 2014, 12:56:01 am »
IIRC most of them are about 256 chars. You can download a RDBMS creation schema and verify the column size for the according table.
Changing the column size has been done by a few people but it's not really recommended as nobody will know the side effects.
P.S: Do NOT use classes in sequence diagrams. Use instances!
« Last Edit: October 30, 2014, 12:57:08 am by qwerty »
Hardy
Re: How many chars EA supports as a "database fiel
« Reply #2 on: October 30, 2014, 12:58:52 am »
why not class in sequence diagram?
« Reply #3 on: October 30, 2014, 02:39:49 am »
a) a SD shows how instances communicate. It's a real life example. A class does not communicate, only an instance.
b) if you VC your model you will simply destroy it this way. It's also written somewhere in the help.
