Author Topic: Problem with RTF Bookmarks in EA11  (Read 6270 times)
tonyhedge
« on: July 26, 2014, 11:12:29 pm »
I've always used RTF Bookmarks to get diagrams into Word, ie:
Generate a diagrams only RTF report
Copy the bookmark for the diagram
In Word, Insert/Text From file, Past the bookmark etc etc.
It has stopped working since I upgraded to EA11. [Edited to add: it no longer inserts the image - nothing seems to get inserted, but there is no error - my guess is that the bookmark is possibly not being associated with the drawing correctly in the RTF, but that is just a guess]
I can still do it with reports generated under EA9 or EA10, so the "Copy Bookmark" bit must still be working. But I can't do it with any RTF generated under EA11.
Am I doing something wrong, or is something changed or broken?
Any ideas?
Cheers
Tony
« Last Edit: July 26, 2014, 11:30:51 pm by tonyhedge »
"Interrupts happen!"
Michael Schneider
Re: Problem with RTF Bookmarks in EA11
« Reply #1 on: August 21, 2014, 10:46:03 pm »
I have the exact same problem. The bookmarks are still in the document. However, in older version the bookmark covered the whole section (e.g. a diagram), while now it is just placed at the beginning of the section. Imagine it like this (the brackets mark the beginning and end of the bookmark):
Old: [diagram]
New: []diagram
So Word will not insert anything, because the bookmarked text is basically empty. This is clearly a bug in version 11!
Michael
tonyhedge
« Reply #2 on: August 21, 2014, 11:34:55 pm »
Michael
Thanks for confirming that, and investigating it further. I'm now using WordEA editor from http://www.oopuml.com/word-ea-editor/. Dramatically simplifies what I am doing, may work for you - I can thoroughly recommend it.
Regards
Tony
Graham_Moir
« Reply #3 on: August 22, 2014, 01:07:14 am »
Have you officially reported the bug ?
Michael Schneider
« Reply #4 on: August 22, 2014, 01:36:12 am »
Yes, I did.
Update: Issue ID is 14088825 and has been confirmed as bug.
« Last Edit: August 22, 2014, 05:28:05 pm by Mittlebenskrise »
Oliver F.
  • ArenĀ“t we all in the model business ?
    • Karl Storz homepage
« Reply #5 on: November 11, 2014, 10:16:16 pm »
Any news regarding a possible fix? That one is annoying and spoils our reporting.
Michael Schneider
« Reply #6 on: November 11, 2014, 11:01:48 pm »
According to Sparx (information from October 3rd), the developers fixed it already, but it needs to be merged into the build. So I would assume that it will be in the next build.
