Author Topic: Status Types Color  (Read 4474 times)
Monsieur
Status Types Color
« on: November 29, 2014, 02:35:28 am »
http://www.sparxsystems.com/enterprise_architect_user_guide/9.0/modeling_basics/statustypes.html
Hello
Does any one have a clue how to have the color on an object (Status Type Color) working on custom elements?
Thank you! ;D
Re: Status Types Color
« Reply #1 on: November 29, 2014, 04:21:37 am »
There is an option which will turn the shadow to take the specific color. It's hard to see. And in one release they made it even worse recognizable. Consider using a shape script to paint an area according to the status using HasProperty("status","..."). This would work for stereotyped elements only.
Monsieur
« Reply #2 on: December 02, 2014, 08:27:48 pm »
Actually, it's all my fault, I forgot to check the correct box ;D.
So if any one need this feature:
1. Go to Tools>Option>object and check the box show object status color and click ok (or apply).
2. Go then in Settings>Project types> General types
3. Click on "apply to..." select your item (or all of them)
As qwerty said before, on most item you will only get a shadow (not really perfect) but on requirement or all custom extension of requirement/changes/issues it work well.
So works perfectly on :
-requirement
-change
-issue
Ridiculous shadow on:
-package
-test cut
-use case
ps: i will update this list later if i find new objects or if you propose some in the comment section below  :D
