Author Topic: RAS: Register MDG Technology: Status unavailable  (Read 4183 times)
thomasbru
« on: December 03, 2014, 11:08:21 pm »
I am trying to register a Technology in a RAS Registry as follows:
1) I created a Diagram with the specific Technology
2) When I register the package the "Register the following MDG Technology" dialog appears (Path http://)
3) I confirm with "ok" but unfortunately the Registry Status is listed as "Unavailable"
4) When another user imports the package the MDG Technology is not available
How do i correctly register MDG Technologies (with source http) with RAS?
Thanks a lot
« Last Edit: December 05, 2014, 12:28:16 am by thomasbru »
Guillaume
    • www.umlchannel.com
Re: RAS: Register MDG Technology: Status unavailable
« Reply #1 on: February 01, 2016, 09:45:18 pm »
I came across the same issue and it works when you use a remote MDG (stored in a "shared" XML file) -> when you import the models from RAS in a client EA project, the MDG is installed with the same path to the MDG (works if the XML is on a url or shared drive that is visible on the local PC).
It would have been nice to use relative paths as set in Tools > Local Directories & Paths, however it doesn't seem possible to link an MDG to the XML via a relative path e.g. %MDG%/mdg.xml
« Last Edit: February 01, 2016, 10:41:41 pm by Guillaume »
Guillaume
