Author Topic: How do I delete a project shortcut?  (Read 5170 times)
andykennelly
« on: December 04, 2014, 08:56:36 pm »
I know how to create a Project Shortcut such that a specified diagram is opened when a project is launched.
However, I can't work out how to delete a shortcut.
I can't find anything in Sparx Help for 'Project shortcuts', nor anything on this forum.
Any ideas??
Re: How do I delete a project shortcut?
« Reply #1 on: December 04, 2014, 10:51:24 pm »
You just delete the .eap file.
« Reply #2 on: December 05, 2014, 09:32:50 am »
...but only if it actually IS a shortcut. A shortcut .EAP file is usually less than 1KB; a .EAP model is usually more than 1MB. Please don't delete your model!
Note that there are other ways than shortcut files to open a diagram on opening a model. You can set a default diagram by Diagram > Advanced > Set as Model Default or Set as User Default. I may be wrong, but I think the only way to clear those settings is to set them to a dummy diagram and then delete the diagram.
And another way to define which diagrams to open on opening a model is to define a Working Set, currently to be found under View > Working Sets.
