Author Topic: EA10 - Failed to initialize Javascript engine  (Read 6033 times)
RIL
  • -- There's always a solution --
« on: December 28, 2014, 02:45:43 am »
Hi all,
EA10 on Win7 Ulitmate.
I'm trying to debug a VBscript (not javascript) but I keep getting the following debug log:
[84269569]      Stack recording threshold set to 3 frames
[84269632]      Default Directory is C:\Windows\system32
[84269633]      Agent dll found: C:\Program Files (x86)\Sparx Systems\EA\VEA\SSScriptAgent.DLL
[84269633]      Default Directory is C:\Windows\system32
[84269633]      Agent: Started
[84269673]      Failed to initialize Javascript engine
So far I can only close the debugging session, nothing happens (no execution) and I can't step or anything, only close down the debugging session.
I also tried to turn off all script debuggers except for VBscript.
All the related dlls are located in the C:\Program Files (x86)\Sparx Systems\EA\VEA folder (6 dlls).
Shouldn't this work "Out of the box"?
// Rolf Lampa
« Last Edit: December 28, 2014, 01:56:01 pm by Rolf_Lampa »
Re: EA10 - Failed to initialize Javascript engine
« Reply #1 on: December 29, 2014, 08:45:01 am »
Ideally it would work "Out of the box", but it depends on external components found on many computers, but that we can't redistribute.
First thing to do is check if a later version of EA will help. Make sure you're using at least 1007. That build says that it provides more information to identify errors. I suspect it also addresses the fact that the error message incorrectly reported trying to create a Javascript engine.
RIL
« Reply #2 on: December 29, 2014, 05:15:21 pm »
Ideally it would work "Out of the box"...
First thing to do is check if a later version of EA will help. Make sure you're using at least 1007. ...
I'm using 10.0.1006 Ultimate. I thought that was the last one before EA11...
Anyhow, I couldn't find any later version for download. Do you have any link to 10.0.1006+ ?
// Rolf Lampa
« Reply #3 on: December 30, 2014, 08:57:39 am »
Last build of 10 (1010) - http://www.sparxsystems.com/securedownloads/easetupfull10.exe
Current Stable (1113) - http://www.sparxsystems.com/securedownloads/easetupfull.exe
Pre-Release (1205) - http://www.sparxsystems.com/securedownloads/EA120_Reg_rc1.msi
Take your pick, but you need to be a registered user for any of those downloads
