Author Topic: Dashed-line Notation for Control Flow  (Read 7498 times)
henagon
« on: March 23, 2015, 06:49:25 am »
I'm a new user of EA (v11) and am utilising the SysML v1.3 toolbox.
I am creating an Activity Diagram, and have specified a Control Flow between two actions.
By default, EA shows the Control Flow as a solid line. This is identical to the way in which EA shows an Object Flow.
To add clarity to my diagram, I would like to show the Control Flow as a dashed-line.
This aligns with the SysML spec, and most example activity diagrams I have seen.
For example, see the dashed-line control flows on the left of this diagram (and compare with the solid-line object flows on the right):
Can anyone suggest how to achieve this with EA?
Kind regards,
henagon
Re: Dashed-line Notation for Control Flow
« Reply #1 on: March 23, 2015, 09:20:37 am »
Create a stereotype, give it this shape script, and apply the stereotype to all of your control flows
shape main
      noshadow=true;
      setlinestyle("DASH");
      moveto(0,0);
      lineto(100,0);
label middlebottomlabel
      print("");
henagon
« Reply #2 on: March 23, 2015, 08:38:47 pm »
Hi KP,
Many thanks for your extremely swift response.
I have implemented your suggestion, and learnt a lot about stereotypes and Shape Script in the process - thank-you!
This 'almost' does what I need - but not quite.
I have a Control Flow defined from a decision node, with a guard specified, which by default looks like:
I would like to display the guard on the diagram, and style the Control Flow with a dashed-line.
Implementing your suggestion - the Control Flow has a dashed-line but the guard is not displayed:
I modified the Shape Script to remove the 'label middlebottomlabel { ... }' portion. The guard is now displayed, but unfortunately so is the stereotype name which adds significant clutter to the diagram:
Reading the description at this website https://leanpub.com/shapescript/read#leanpub-auto-hash-tags, I tried modifying the Shape Script with the following:
label middlebottomlabel { print("#guard#") }
Unfortunately this does not work - the guard is still not displayed.
Any ideas where I'm going wrong?
Kind regards,
henagon
philchudley
« Reply #3 on: March 23, 2015, 10:35:21 pm »
To suppress the control flow stereotype labels you could try
1) Open Diagram Properties
2) Select Connectors
3) Uncheck Show Stereotype Labels
Phil
Models are great!
henagon
« Reply #4 on: March 23, 2015, 11:49:20 pm »
Hi Phil,
Perfect!
Many thanks,
henagon
