Author Topic: Show Complexity on element in diagram  (Read 5254 times)
Robert Lelieveld
« on: April 10, 2015, 06:09:58 pm »
In the general settings of e.g. the Interface object of the UML deployment diagram, there is a standard property called Complexity.
I'd like to show that on the element in the diagram.
How can this be done?
Tagged values can be shown, but I rather not create a duplicate field.
Re: Show Complexity on element in diagram
« Reply #1 on: April 10, 2015, 06:23:28 pm »
You can't show that (directly). Without checking this personally: a shape script would be able to display it, but only for stereotyped elements.
Robert Lelieveld
« Reply #2 on: April 10, 2015, 09:19:49 pm »
Hi qwerty,
Thanks!
I didn't know about Shape Script.
Currently I added this:
shape Main
      PrintWrapped("#Complexity#");
      DrawNativeShape();
Is it possible to have EA add this below the already shown Type and Name ? I tried to add a compartment (nothing happens) or add a decoration (in the center right over the Name), but can't make it to work.
- Robert
« Reply #3 on: April 10, 2015, 10:09:15 pm »
Try this one:
decoration c {
  orientation = "s";
and have a look into my Shape Script book :)
Robert Lelieveld
« Reply #4 on: April 10, 2015, 10:57:38 pm »
Nice!
Tried this:
decoration c {
      orientation = "s";
      PrintWrapped("Complexity #Complexity#");
However, this code will create two lines of which the second is outside of the shape.
Also tried this one:
shape Main
      SetCompartmentName("Complexity");
      AppendCompartmentText("#Complexity#");
      DrawNativeShape();
But no compartment is added?
The example in your book in chapter 2.5 is very nice. Might that only work with child elements and not with Main properties and values?
« Reply #5 on: April 11, 2015, 01:01:53 am »
The compartment will not work this way. You can try a subshape instead (see p. 19). Shape Script has its peculiarities...
« Last Edit: April 11, 2015, 01:02:54 am by qwerty »
« Reply #6 on: April 15, 2015, 12:18:32 pm »
SetCompartmentName and AppendCompartmentText are only available for child/related element shapes.
Try just changing PrintWrapped to Print.
