Author Topic: [SOLVED] Using SSL with CloudServer  (Read 13602 times)
coatie
« on: April 14, 2015, 04:42:42 pm »
I created a self signed SSL certificated using the openSSL commands described at
http://www.sparxsystems.de/fileadmin/user_upload/pdfs/Cloudservice/Enterprise_Architect_Cloud_Services.pdf (see last page)
The server.pem is successfully generated but I am getting following error when starting the CloudServer-Service:
[WARNING]: Unable to create secure server on port 805. CA Cert file not found not found at C:\Program Files (x86)\Sparx Systems\Cloud Services\Service\cacert.pem
SSCloudServices.config contains following:
SERVER_PORT=805
REQUIRE_SSL=1
Do I need to create a CA certificate as well?
Markus
« Last Edit: April 15, 2015, 03:55:14 pm by coatie »
Re: Using SSL with CloudServer
« Reply #1 on: April 15, 2015, 12:27:16 pm »
Normally this file would be created by the installer.
I don't think it matters what the contents are. We haven't implemented support for client validation by certificate.
coatie
« Reply #2 on: April 15, 2015, 03:54:38 pm »
Thanks a lot Simon!
Must have accidentally removed this file and could restore it from the installer. Now the server does provide the SSL connection.
Markus
