Author Topic: Import code from directory into different packages  (Read 3611 times)
survex
« on: April 09, 2015, 12:38:29 am »
Say I have code in Z:\code.
I'm adding package A in EA and import code from Z:\code into A - it works fine, great!
Then I add package B and import code from Z:\code into B - B remains empty.
So I can't add to same file as different classes in EA?
Is there any way to hack it?
Re: Import code from directory into different pack
« Reply #1 on: April 15, 2015, 09:42:03 am »
What you are seeing is correct. EA will update the original elements instead of creating new ones.
The best "hack" I can think of is to create a local path before importing the first time. Before importing a second time, change the local path to point to a different location. This will tell EA that the classes it is seeing are different from the ones already there.
survex
« Reply #2 on: April 17, 2015, 08:15:18 pm »
Thank you! I'm solving this problem in similar way, just creating symlink for each code importing in EA, e.g.
A -> A1 (symlink) -> import in EA package A1
A -> A2 (symlink) -> import in EA package A2
