Author Topic: Import DB schema, Oracle 12C  (Read 7069 times)
niasilil
« on: April 01, 2015, 12:40:45 am »
We have EA 9.2.921 version. We have switched from Oracle 11g to 12C recently. I cannot make EA work with the database.
My steps:
1) created new project and data model
2) import DB schema from ODBC link via a Project browser icon
3) clicked "..." button, clicked "New", Oracle in OracClient, chose corresponding TNS name, tested connection and clicked OK.
4) clicked "Import"
5) as a result I get 0 of 0 available objects to import, no matter what I type in schema/owner option.
I tried using Microsoft ODBC Oracle driver in step 3, no success either.
Please, advise. (If I am not mistaken, we have an enterprise level perpetual license, EA Corporate Edition)
« Last Edit: April 01, 2015, 12:41:08 am by niasilil »
hd
Re: Import DB schema, Oracle 12C
« Reply #1 on: April 01, 2015, 07:40:15 am »
Support for Oracle 12C database engineering was introduced in EA 11.0 Build 1107. You will need to upgrade to the current release.
phokanson
« Reply #2 on: April 30, 2015, 02:00:09 am »
Is there any resolution to this?  I can't get the import schema through ODBC to work either in v12.  I just updated to the latest (April) release but still doesn't work.  I'm connecting to a SQL server DB.
« Last Edit: April 30, 2015, 02:14:04 am by phokansontx »
« Reply #3 on: May 01, 2015, 04:06:04 pm »
This issue was only related to that specific version of Oracle. If you have a problem reverse engineering an SQL Server database then that is totally unrelated. You better make a new topic and provide enough details so people can help you.
You can also contact Sparx support if the other users can't help you.
