Author Topic: EA 12 not working with Team Foundation Server(TFS)  (Read 4874 times)
Ricardo Bicalho
« on: May 30, 2015, 04:44:05 am »
Enterprise Architect 12 build 1214 is not being able to sync with Team Explorer when Team Foundation Server - TFS is used as the version control. This issue does not exist on EA 11.
Version Control Settings
Type: TFS
Check-out a package and then try to check-in:
"You cannot check-in package "Maintenance"
The associated file 'ea7\721EEFC247FB' is not currently check-out by you.
However, I confirm that it is indeed checked-out to me using Package Control > File Properties...
Also confirmed with Team Explorer, but EA 12 fails to recognize this.
I tryed, at last, Re-sync Status With VC Provider and it gave the following error:
Resynchronizing status of the selected version controlled package, with its Version Control Provider.
   Package: 'Maintenance' - WARNING: Package marked as 'CheckedOut' to 'ricardo', but XMI file reported as 'Out To Other' - cannot synchronize to this state.  Clearing 'CheckedOutTo=' value from package.
Any ideas? Is that a bug or a configuration problem? This error does not occur on EA 11.
AndyJ
  • It's only a model
Re: EA 12 not working with Team Foundation Server(
« Reply #1 on: June 01, 2015, 02:53:24 pm »
Just in case it helps...
Have you seen this post?
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1424944655/2#2
shock
Re: EA 12 not working with Team Foundation Server(TFS)
« Reply #2 on: January 12, 2016, 11:28:40 pm »
Same problem here. Did you find a solution already?
