Author Topic: RTF Template - Custom Stylesheet  (Read 4677 times)
« on: June 22, 2015, 11:23:27 pm »
I know that when I generate a document I can select a customer style sheet, but how do I apply the customer style sheet when I'm editing a template?
The drop down list has all the system style sheets in, but none of the custom ones?
Re: RTF Template - Custom Stylesheet
« Reply #1 on: June 23, 2015, 02:11:49 am »
I've worked out how to do this:
You go File -> Update Styles and you can 'overwrite' the styles in your template with those from a style-sheet.
Just have to remember to do this when you make changes to the stylesheet if you want it to look correct in the template
« Reply #2 on: June 23, 2015, 03:51:51 pm »
If you do the same with the normal.rtf all your new templates will already contain the styles in your custom stylesheet.
