Author Topic: Placing (dashed) lines and dashed high phases  (Read 6312 times)
Gladio
« on: July 06, 2015, 08:01:29 pm »
I was wondering whether there is a possibility to use/place single (dashed) vertical lines and (dashed) high phases within an timing diagram in enterprise architect.
Thanks and regards
Re: Placing (dashed) lines and dashed high phases
« Reply #1 on: July 06, 2015, 09:19:07 pm »
Unfortunately we do not have access to your C: drive. Place the picture on a public server, please.
Gladio
« Reply #2 on: July 06, 2015, 09:29:28 pm »
I want to add (dashed) vertical lines like the red one and dashed high phases like the green one.
« Last Edit: July 06, 2015, 09:30:30 pm by k.ozdemir »
« Reply #3 on: July 06, 2015, 10:16:15 pm »
I'm afraid this is not UML compliant. UML 2.5 makes use of dashed lines only for GeneralOrdering. I see the use of those dashed/colored lines but ...
What you can do (well, ...) is to mimic lines using boundaries you make invisible by assigning an alternate image. Very awkward but I have no other idea.
« Last Edit: July 06, 2015, 10:20:12 pm by qwerty »
Gladio
« Reply #4 on: July 10, 2015, 06:37:18 pm »
I've found the following in UML 2.5 specification (http://www.omg.org/spec/UML/2.5/Beta2/PDF/):
A Lifeline is shown using a symbol that consists of a rectangle forming its “head” followed by a vertical line (which may be dashed) that represents the lifetime of the participant. (PDF page 644; Chapter 17.3.4 Notation; Lifeline)
It seems like dashed lifelines are generally possible, but not possible in EA?
Regards
« Reply #5 on: July 10, 2015, 09:07:29 pm »
A lifeline is part of a sequence diagram, not of a timing diagram.
