Author Topic: How to set the default status for elements?  (Read 4031 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: July 30, 2015, 03:48:11 pm »
I have set a different list of Status for elements (from General Types windows) and I like one of them to be set as the default state when a new element is created. How can I set this?
I also have a Profile with stereotyped elements (if it helps), so maybe there is a non-documented attribute to be used in the stereotype or the metaclass to set the default Status when creating a new element by using the profile?
Re: How to set the default status for elements?
« Reply #1 on: July 30, 2015, 06:43:41 pm »
I don't think there is any such setting. You might try with template packages (just a guess). The only definite way I know is to write an add-in that subscribes to EA_OnPostNewElement where you can change things like that.
« Last Edit: July 30, 2015, 06:44:11 pm by qwerty »
