Author Topic: Transfer Data to EAP  (Read 6254 times)
Tehila1
« on: August 16, 2015, 10:19:22 pm »
I encounter an error while trying to transfer DB data to a simple eap file.
I paste the connection string as the source and an almost-empty eap model as target.
The following error is displayed:
"The selected source database driver is not supported by EA".
Any ideas?
Thanks in advance!
Re: Transfer Data to EAP
« Reply #1 on: August 17, 2015, 04:07:05 am »
Those connection strings are tricky. Can you post yours?
Tehila1
« Reply #2 on: August 17, 2015, 03:53:11 pm »
How can I retrieve the connection string from my DBMS model?
I tried the Repository.ConnectionString, but it returns the model path instead of the connection string. Again, this is not a simple JET EAP model, it is a DBMS (Oracle)
Any ideas?
« Reply #3 on: August 17, 2015, 04:22:26 pm »
Make sure you use the correct driver for the connection to your Oracle model.
IIRC that should be the "Oracle OLEDB" driver.
ducatiross
« Reply #4 on: August 17, 2015, 06:15:35 pm »
Hi Tehila1,
I've never been able to get the Transfer DB to EAP file process to work. I have to export the parts I want as XMI from the DB then load them into an EAP file.
« Reply #5 on: August 17, 2015, 06:22:02 pm »
You said "I paste the connection string"
