Author Topic: to align sequence flows  (Read 3777 times)
Michel777
« on: August 27, 2015, 01:38:01 am »
Is it possible to align sequence flows (SFs), like:
1) to put some SFs in a line
2) to participate SFs for align center (Tasks)
3) to bind together several SFs, they end at the same task
HarryPlotter
Re: to align sequence flows
« Reply #1 on: August 27, 2015, 02:22:51 pm »
Hi there, I presume this is about BPMN diagrams.
Each connector represents the flow of a token from a source object to a target object. There is no 'multibranch'. But often humans like it presented so it looks that way. In the past I have laid connectors on top of each other to do just that.
Set 'snap to grid' and use the same 'line style' for each connector and you should get the visual effect you may be seeking.
