Author Topic: Project Transfer and Security  (Read 4306 times)
andrewd
« on: August 27, 2015, 09:08:11 pm »
I have been able to do project transfers in the past but with security enabled I get a prompt to enter "Login to EA Repository" and enter "User ID" and "Password".  I enter the user ID and Password for the database (on the server) but the system says I have incorrect credentials.
Re: Project Transfer and Security
« Reply #1 on: August 27, 2015, 10:37:10 pm »
This is a known bug - apparently caused by the changes to password security between version 9 and v12.
If you search the forum in the last couple of weeks you'll see my posting on it.
It seems they missed one in the change over.
Please report a bug (as I did).
« Reply #2 on: August 27, 2015, 11:32:31 pm »
Workaround: turn off security in the target database before transferring.
andrewd
« Reply #3 on: August 28, 2015, 01:15:54 am »
I thought it was an issue with the security for the model on the server, but it turns out it was the local .eap file that I was trying to write to.  I removed security on the destination file as you said and it solved the problem.
